HI GUYS + GIRLS AS THE HEADING SUGGESTS I'M AFTER PICS OF ANYONE THAT HAS BIULT AN RB 20 FORWARD FACING PLENUM THAT RETAINS THE STADARD LOWER HALF OF THE INTAKE MANIFOLD (LOWER RUNNERS)??? I JUST NEED IDEAS I DON'T WANT TO GET A SMALLER BATTERY OR RELOCATRE IT TO THE BOOT SO JUST AFTER IDEAS ON HOW I CAN DO THIS??
THANKS
Wheezys actually worked real well, i was happy witht eh resuls on the dyno. i would be happy to use someting like this on my own cars.
yeah all of them look good but i'm actually after pics of some that use the complete un-modified bottom runners and have made their own top box so to speak???? couldn't find any in the fabrication forum????
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
