what size is the hole and it doesnt matter if you go into the water gallery does it just a bit of lock tight and all is sweet yeah
the tensioner is m10x1.5 and yes u go into the water gallery, worked out perfect from the pdf document measurements, possibly a touch tight but i can get the belt on so thats good.
i bought a s1 block and managed to not notice it had the uneven cast face for the bottom idler so it didnt sit right, we used some liqued metal and made a flat face, worked great and was easy to do.
just gotta send the block off for decking and tap the oil drain hole (we havent got a tap and drill bit that big so ill leave it to the machine shop).
Then i can throw the parts back in and the head is all complete, just need some bigger shims and its almost ready to go.
Need to decide on what turbo to go for now, i got a limit of 430rwhp or so and dont wanna run more than 18-19psi boost if possible. Its either gt3040r, gt3076r or gt3540r, decisions decisions :wave:
i have the same problem with the bottom tensioner. the hole for it is allready there however no surfast to sit on, after reading the liquied metal idea i went and purchased some selleys stuff.
however it says will only handle 120C of heat. would the constant spinning of the tensioner create a friction heat of excess of that is what i am wondering, considering if it did fail and the tensioner let the belt slip off it would cause some rather major damage.
or would getting a cast iron welder to fill it up then smooth over be a better option.
or just buy the right block in the first place, hits self over back off head
i bought some and its rated to over 300C of heat from memory, the tensioner doesnt spin on the block surface, the part bolting onto the block is sitting hard on the face of the block and doesnt move.
heres a pic of the tensioner spot setup with the liquid metal....
to hold the liquid in when its drying i used a bit of bluetack and made a little barrier to stop it running all over the place, put the tensioner stud in WITH oil on the threads and then just fill it up till its abit above flush and then let it go off for 20 min or so, wind the bolt out a fraction as to make sure its not stuck in and then file the surface flat using the waterpump surface etc as a guide to get it spot on. The bolt can then be takin out and the threads remain so u can screw it in and out without any problems.
what was the brand name of this product and what store was it in. i could only see one type of metal substance at bunnings prolly not the best store for it but it was more of a putty. also i noticed that the hole for the tensioner bolt in that position sits back into the block abit making the bolt shorter then the top tensioner and cam gears?
Edited by ahh 33 s2
just an update on the idler mounting on a s1 block. I just tried to torque the idler pulley onto the liqued metal flat spot and it distorted the flat spot so looks like ill have to sort something else out, mayybe i should of made the flat spot a fair bit bigger, ill update when i find a solution. Pity i spent money on the block decking it and acid bath etc, now its all assembled and i find this damn problem :D
Edited by unique1
thanks mate for the idea, i got something else lined up first i shall try, ill post info once i see if it works or not. I dont really wanna weld the block as its been decked now and internals are all installed, do u think anything would be effected if i heated up the idler area to braze it up?
yeah I had this prob a little while back on one of my first builds, ended up making a custom washer about 1cm thick that fits over the stud and is ground away on an angle underneath to suit the block. Hardest part is getting the correct angle on the washer underneath so that when the tensioner torques down, it doesn't come off centre, had it done in a day of mucking around with the grinder tho.
Well i have sorted the problem most likely, ended up welding up the area and grinding it flat, looks good and should work ok, i have bolted idler on and its fine, havent fitted the belt yet or run it so not gonna say its worked until its actually running :D
what did the welding set you back
i did it at home so it was free, took a while trying to not get too much heat into the block and distorting the water pump area of the block, took a good hour or so as its alot of metal area to build up. We did a test run on a spare old rb26 block i got here to make sure it would stick and work ok :D
As i said i wont say its 100% right until i see the motor run for a while, but looks like the best option available if u happen to get a s1 block.
    • Yeah pretty impressive hey, good to see quality products not over-shooting their prices. That's what drew me to buy the hypergear turbo, just a shame I've never got the chance to see it in action
    • Thank you GTSBoy and MBS206 I have done the compression test with the motor out of the vehicle, reason for the test was to see if I needed to remove the head and do rings etc while its out. I'm in the process of respraying the vehicle and tidying up a few things. Story behind it all is I've just purchased the skyline and it was running when I got it, never drove it on the street though as I wanted to pull it down and do it all up again before registering it. the gentleman I purchased it from told me the motor has a forged bottom end and has a decent tune through it but I was going to pull the sump off anyway to see if it is a forged bottom end. that's why I thought id do a compression test beforehand.
    • Man, I'm kind of amazed that the price of the turbo has not changed in 7 years. Everything else is inflating beyond reason, but not this? Good on Tao / hypergear I guess? Anyways, good luck with the sale!
    • I'm selling my brand new, in the box, never used Hypergear ATR45 - and I had some additions I paid for a few yrs back when I purchased it. Never ended up having the rest of the money to add all the mods at once, so I just ended up slowly selling each part. I originally had it internally gated, with the dump pipe, however I found it was incompatible with what I was going to use it for, so I contacted (I think Ken) from Hypergear, and he and I messaged back and forth & he got me to ship the turbo back, where they modified it & made it externally gated, and gave me the 5 bolt dump pipe attachment for custom welding. (Photos below) This turbo like I said has never touched the inside of an engine bay, it's completely brand new, never used, been sitting in the same box it arrived in, covered in plastic & all. Below are the photos of it: And while the guys at Hypergear were making it in-shop, they sent me some photos of the process: I'm looking at selling this just because I'm in need of the money right now, and don't have plans on modifying the 34 anytime soon - and from reviews & peformance sheets, this turbo had amazing results back when I was researching. The turbo was purchased in 2018 for $1.9k, with the mods I got added on. Looking at the website now, for the same turbo they sell (ATR45SAT), with the current addons it adds up to $1830 for the turbo Current addons included: - Bolted dump adaptor - Ball bearing CHRA - Braided oil feeding line So I'm looking to possibly sell it for around $1800, with shipping included in that 1.8k, It cost me around $120 to ship - so yeah thought I'd throw it out there and see if anyone was interested in purchasing. Cheers!
