Item: A pair of Greddy T517Z with 10cm^2. Come with oil line and accessories in pictures below
Age: Used
Condition: Excellent.
Price: 2200 ONO
To Fit: (What car) RB26DETT
Contact: PM
Comments: Good responsive turbo. They were making 422rwkw on a RB26. Perfectly fine on removal. Has the normal side to side shaft play that comes with these bush bearing turbo. There isn't any in/out shaft play that require rebuild. Check my other sale thread if you want the custom dump with the turbo. I will reserve the first dip for the Greddy turbo purchaser...as long as you are quick :P I upgarde to a pair of T618Z but used the existing oil lines and drain. Purchasers will get the new oil lines and drains and what ever else is in the picture ;)
Item: A pair of high flow N1 Turbo. Rebuilt by Adelaide Turbo Service
Age: Used
Condition: In excellent condition
Price: 2000 ONO
Contact: PM
Comments: These turbo came with the car. I've been told they are high flowed N1. Caveat Emtor on this one. These came with the car so I can only go by what I've been told. They are in very good condition and were not in the car long after rebuild by Bill @ ATS in Adelaide. These turbo produce awesome midrange power and low rev response. Perfect for track GTR. There isn't any shaft play at all. Previous owner was saying that these turbo produced around 360 rwkw
High flowed Garrett turbo
Hmmm I should have clean these turbo lol The Canon lens shows the dirt really well :worship:
If you have a set of light weight rims in 18x10 or 18x10.5 with 22 or 25 offset and want to trade, let me know ;)
Edited by 9krpm
PM's replied
The custom stainless dump pipes pictures are in my other Mines exhaust sale thread.
http://www.skylinesaustralia.com/forums/Mi...24#entry4072924
Here are the pictures for the enquirers
You will need these custom dump or the Greddy dump pipes for the Greddy turbo. The wastegates on the Greddy turbo's open in the opposite direction and won't clear most dumps designed for Garrett turbo. The Greddy dumps are expensive and a freaking nightmare to fit. These are easier to fit than the Greddy and still have the bigger 3" diameters. They are big enough to flow the biggest Greddy low mount turbo on any RB engine. I am only asking for 250 for these lol. Purchaser for the greddy turbo will have the first dip for these dumps. Please see my other sale thread if you need exhaust stuffs.
Edited by 9krpm
  • 4 months later...
After a few weeks of chit chats and false promises, I still have these 2 set of great turbo.
Both sets are still good without any oil leaks. Does anyone on here need them?
Please let me know before I put them on ebay.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
