hey guys i need some help
when im driving my HICAS light comes on at random intervals and just stays on
i have had a wheel allignment done many times but still doesnt fix this issue wat could this be also my ABS light flickers on and off abit weird any one have ideas ?? :D
https://www.sau.com.au/forums/topic/232200-need-help/
tried a diagnostic?
http://www.skylinesaustralia.com/forums/HI...tic-t22193.html
thread has some pretty good HICAS discussion.
and a bit of copy-pasta for you:
Maintenance Tips/Suggestions: When turning the ignition switch to the on position, the amber BRAKE, ANTILOCK or ABS light on the instrument panel should glow momentarily, and then turn off. If the light stays on or flashes, or comes on while driving, it indicates a fault in the ABS system. Have your car's ABS system inspected immediately by a professional technician to determine the source of the problem.
Edited by Sonuku
https://www.sau.com.au/forums/topic/232200-need-help/#findComment-4075495
well locking out is an option but i dont want to lose any of the handling that it has with the 4ws my ps pump is leaking and is getting replaced next service as with the abs i have had it inspected and it is working fine but the sensors are prob full of break dust
but i dont know where the sensors are to clean them
https://www.sau.com.au/forums/topic/232200-need-help/#findComment-4075646
You dont lose handling by locking out the HICAS, I noticed that mine handles better without it... The only thing that the HICAS is good for is reducing the turning circle and helping with lane changing at speeds over 60kms.
HICAS just gets in the way if your driving "enthusiastically".
https://www.sau.com.au/forums/topic/232200-need-help/#findComment-4075926
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
