hey guys i need some help
when im driving my HICAS light comes on at random intervals and just stays on
i have had a wheel allignment done many times but still doesnt fix this issue wat could this be also my ABS light flickers on and off abit weird any one have ideas ?? :D
https://www.sau.com.au/forums/topic/232200-need-help/
tried a diagnostic?
http://www.skylinesaustralia.com/forums/HI...tic-t22193.html
thread has some pretty good HICAS discussion.
and a bit of copy-pasta for you:
Maintenance Tips/Suggestions: When turning the ignition switch to the on position, the amber BRAKE, ANTILOCK or ABS light on the instrument panel should glow momentarily, and then turn off. If the light stays on or flashes, or comes on while driving, it indicates a fault in the ABS system. Have your car's ABS system inspected immediately by a professional technician to determine the source of the problem.
Edited by Sonuku
https://www.sau.com.au/forums/topic/232200-need-help/#findComment-4075495
well locking out is an option but i dont want to lose any of the handling that it has with the 4ws my ps pump is leaking and is getting replaced next service as with the abs i have had it inspected and it is working fine but the sensors are prob full of break dust
but i dont know where the sensors are to clean them
https://www.sau.com.au/forums/topic/232200-need-help/#findComment-4075646
You dont lose handling by locking out the HICAS, I noticed that mine handles better without it... The only thing that the HICAS is good for is reducing the turning circle and helping with lane changing at speeds over 60kms.
HICAS just gets in the way if your driving "enthusiastically".
https://www.sau.com.au/forums/topic/232200-need-help/#findComment-4075926
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
