Hey guys. Well i installed my boost gauge and my Festo Pneumatics bleed Valve and headed off to Morpowa to get it tuned. Anyway the result was a very impressive 183rwkws at 11psi. The bleed valve was quite good, however there is a spike at around 3500rpm where it goes to 13psi.
Anyway im very happy, it feels alot more responsive, But i think my clutch is now slipping :P Im not too sure.
Now i need to heat wrap my front pipe and make my CAI partition, then A FMIC hehe.
Dyno printout to come later.
Cyas tonite
https://www.sau.com.au/forums/topic/23244-dynoed-my-car-yesterday/
Nice result Dean thats excellent power with stock cooler, must be a nice fresh engine. I think my clutch said enough at about that sort of power - time for a twin plate:D
Hope you didnt have tooo much fun in the wet last night;)
BOOSTD, were those results with CAI? My car got alot more responsive with a CAI and partition. Dont know about dyno results cos they always did them with the bonnet up:)
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
