  • Replies 51
Do a couple of hard launch, then pull over. If you can smell something similar to brakes (assuming you didnt stand on the brakes:)) you probably got slipping clutch.
Basically the engine will be accellerating, but the cars accelleration will be very sedate by comparison. I remember when mine went, I would pull away gently and all would be ok, if I tried to give it too much stick, if felt (and was) alot slower even though the engine revved hard - if you know what I mean.
Another dead giveaway is smoke coming out the front of the car near the back of the front wheels after you have done your launches (well mine did anyway).
Mine slips when I slap third gear, however slapping second causes wheel spin until around 90-95kays where third is.
I've got one of those purple looking pressure plate ones that has 30% more pressure. Its not the best I must say, heats up to quickly and slips, even since day one.
I tell ya what... it must be scary doing 90-95km/h with the back end out of control, I hate it when just doing like 20-30km/h hehe.
Unless I drop the clutch from >1700rpm in 1st gear I can't break traction any other way (or gear). Can't wait to get rid of these 225's and throw on some 255's on the rear it'll be unreal.
Guest Robo's
Originally posted by Steve
Mine did with stock cooler, got a FMIC and it held boost all the way to redline.
Horsepowerinabox have a write up on the stock cooler saying it drops something in the range of 7psi at 6000+rpm, its on the cooler upgrade for R33 pages, worth a look.
If what they say is true, when you are reading 10psi at 7000rpm, your turbo is actually making 17psi as boost is measured at the plenum.  This is probably why its not a good idea to boost over 10psi (or try to) with a stock cooler;)
Is that an article in a book or a web page?
Guest Robo's
My thing spins at any speed in first gear, as soon as it hits boost it spins. Its due to my tyres. There 255/40/17 but they are hard as, tyres dont feel sticky at all. Need some new ones. Anyone got any cheap?
I've got the same core.
If I set boost above 13psi with the standard turbo I get boost drop with the ebc in manual mode. With the EBC in Auto it will hold boost all the way but it does waver slightly and makes slightly less boost in lower gears, nothing the a manual channel of scamble can't fix though.
With the bleeder I experienced exactly the same. I did notice that after fitting the fmic 3rd gear felt stronger and consistent where as with the stock IC after a few hard gears the heat soak must have set in and power would start to feel flat in the higher gears.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
