Let's do it again :)
Gokarting for 8pm Friday 5th September subject to availability of booking!
We will again do the Team Enduro Race which requires a min of 16 people and a max 28.
It's a 2 team race with 40 laps each.
Monies payable the week before. Meet at Vilis 7.30pm Friday 29th August.
Thats karts in 3 weeks, and monies due in 2 weeks. Is that do-able for most?
who's in? :D
  • Replies 49
Karting 8pm Friday 5 September 2008
Enlisted so far is:
RubyRS4 (reuben)
InH3aven32 (scott)
Whiplash (nick) - maybe
Madaz (steve)
Matty31 (matty) - maybe
Damo_R34 (damien)
Craig_R33 (craig)
rad32 (adrian)
:thumbsup:
Definately count me in for this event.
Car comes off defect on the 3rd so should be good to bring the ride out after soo long of not being able to drive it.
well i suppose i should come and defend my title :( lol
I will see if Luke wants to come as well
So both of you will have to defend your titles
yeahhhh ill be in, better bring a spare nissan badge, see if it makes my cart faster :P
Nissan badge FTW
Extra kilowasps
i will bring mine as well need all the power we can get lol
woot im in... bring it on!!!
your on adriano.
BTW i am keeping your 16s for a wee bit longer
thanks dude
UPDATE:
Enlisted so far is:
RubyRS4 (reuben)
InH3aven32 (scott)
Madaz (steve)
Damo_R34 (damien)
Craig_R33 (craig)
rad32 (adrian)
Chefstagea (adam)
Kidafa (chris)
Scandyflick - maybe
Bunny33 (kellie)
Krishy
To all those interested ...
If we don't get the numbers needed for the 80 lap race, we will still go ahead with another platform of racing on the night (which is cheaper btw). So racing will be had! :blink:
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
