Let's do it again :)
Gokarting for 8pm Friday 5th September subject to availability of booking!
We will again do the Team Enduro Race which requires a min of 16 people and a max 28.
It's a 2 team race with 40 laps each.
Monies payable the week before. Meet at Vilis 7.30pm Friday 29th August.
Thats karts in 3 weeks, and monies due in 2 weeks. Is that do-able for most?
who's in? :D
  • Replies 49
Karting 8pm Friday 5 September 2008
Enlisted so far is:
RubyRS4 (reuben)
InH3aven32 (scott)
Whiplash (nick) - maybe
Madaz (steve)
Matty31 (matty) - maybe
Damo_R34 (damien)
Craig_R33 (craig)
rad32 (adrian)
:thumbsup:
Definately count me in for this event.
Car comes off defect on the 3rd so should be good to bring the ride out after soo long of not being able to drive it.
well i suppose i should come and defend my title :( lol
I will see if Luke wants to come as well
So both of you will have to defend your titles
yeahhhh ill be in, better bring a spare nissan badge, see if it makes my cart faster :P
Nissan badge FTW
Extra kilowasps
i will bring mine as well need all the power we can get lol
woot im in... bring it on!!!
your on adriano.
BTW i am keeping your 16s for a wee bit longer
thanks dude
UPDATE:
Enlisted so far is:
RubyRS4 (reuben)
InH3aven32 (scott)
Madaz (steve)
Damo_R34 (damien)
Craig_R33 (craig)
rad32 (adrian)
Chefstagea (adam)
Kidafa (chris)
Scandyflick - maybe
Bunny33 (kellie)
Krishy
To all those interested ...
If we don't get the numbers needed for the 80 lap race, we will still go ahead with another platform of racing on the night (which is cheaper btw). So racing will be had! :blink:
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
