Hi all,
Just picked up my V35 and had a bunch of CD's ready to throw into it only to find that a CD appears to be stuck in the unit. When you start the car it makes noises like it's trying to eject a disc then eventually gives up and displays the message "CD ERR FO" on the screen.
I've googled this and tried giving the unit a tap on the side with my hand and also holding down the eject button while trying to insert a CD but neither have worked. Has anybody come across this problem in their car and been able to fix it?
I'm over 89.9 Light FM already!!
they would have left a cd in the car when it was shipped and it has dislodged on the trip over... you'll probably have to pull it apart and remove the cd. If you have warranty take it to them and let them sort it out...
got $$ and LOTS of it. CD mech is stuffed. also it is NOT that easy to get the discs out as the above poster thinks. you will have to TOTALLY strip the unit down to NOTHING before you get one of them out.
in short the mech has to be rebuilt.
if you can get the thing out send it to me and I'll fix it.
give me a ring (contact in sig.) if interested.
there is a sequence to gethte unit into service mode and from there you ca do things with it. thing is if the mech is jammed you have buckleys of getting the disc out. been there already - twice.
  • 4 months later...
Yeah, been there once... However, there twice now... :) And I think the mechanism is stuffed, because it is producing a rather unhealthy sound compared to what I remember 2 years ago... :)
This could be in the wrong thread, but has anyone experienced a loss of sound quality with installing an after-market head unit in a Bose fitted car? Why I am asking is in my previous car, AU Fairmont, after I replaced the head unit to JVC, the bass level dropped. Would I experience the same with another head unit here? The head unit I am looking at is this: http://www.oo.com.au/JVC_Car_Stereo_with_8...__P9851C448.cfm
Somehow "Maximum power output: 4 x 50W" is telling me it won't work as well...
if done with the correct interface lead - no loss at all. in regard to the previous fix onthe stacker - did you get the WHOLE lot changed or simply the dud guide replaced.
also to pop that JVC unit in you have to spend $6-700 more on panels, controllers and leads.
Isn't there a reset button like on bose sound systems? Where by pressing a combination persistently it spits out the CD? (And no, not dreaming, have done it before when it went caputs...)
russky, can you post what the sequence is as I have the dreaded disease on my bose too and its probably worth a try although I'm not holding my breath for it.
Anyone else know the reset sequence please feel free to post. Its for the 01 bose in my 300gt
Thanks.
I have the same problem too. Tried all methods and no go. Will try to open the thing on the weekend. see what i can do.
Had another problem today. Really hot day, car parked in the sun. When i turned my engine on, the monitor will not turn on. When I pressed "TV" i'll have the japanese lady say something. Parking cameras won't work either. Not sure if its the heat, but the thermostat says 45 degrees!!! hopefully it'll fix itself
john,
run it past when you get a sec. (ring first.)
I'm considering grabbing a few of these units and doing them on an exchange basis since most of you are having dead units on a regular basis.
  • 3 weeks later...
Could this be the same sort of problem that I sometimes have with my Kenwood system in my 2002 NZ new Galant?
On a very humid day, the rollers that eject the disc (it's a single disc slot load CD player) seem to have absolutely no grip what so ever on CD-R's. Sometimes I've found it just turning and slipping while trying to eject the CD but no CD coming out. Today I had the problem of it not gripping the CD to take it in because the weather today is so hot and extremely humid (so bad the paper is soggy lol). This problem always sorts its self out (always has so far "touch wood") when the air dries up again (or I have the A/C on for a long trip).
Could it be that parts of the Skyline CD player that grip the CD's to eject them get greasy and just can't grip the CD causing this problem? Espically since the Skyline system is 6 disc and it may be getting jammed further down in the system. Maybe there is someway to clean the rollers without disassembling the whole stereo that would prevent this problem.
Just my 2 cents but I hope it helps :D
they have various internal issues. the main one is the nylon guides that splinter and destroy the rest of the mech. on some the switches die others lose a motor (there are 3 that run the thing.) all resulting in a BIG mess.
alpine did a similar thing on the 90s the rollers ad the spindle tray would lock a cd into place with heat and you could not get the disc out.
O ok, hmmmm, that's not good =[
I am planning to get a V35 Skyline in the 2nd half of this year, and if I was to have the same problem with the CD player, and I was able to find someone to repair it (I live in NZ so I dunno who could repair it- but JDM cars are very common here so even V35's shouldn't be too much trouble-fingers crossed as I see at least 5 each day if I'm in city), would it be possible to put stronger parts in place of the nylon parts to increase the reliability?
Thanks Chris,
Matt.
not really. clarion revised the mech in later applications so it does not do this. bad part about this - new mech will not suit this application.
in regard to repairing. I do them - I am working on recalibration of the FM radio now so once that is done I'll start doing more of them.
Edited by Chris Rogers
Ahh damn lol, well I guess if it breaks then get it repaired and hope it doesn't break again LOL.
Yes, if I was in Australia then I would come to you to get it done haha, but I'm in NZ and getting you to NZ isn't cheap :banana: .
I do like the idea of the recalibration of the radio though because currently, I can't imagine not having a normal tuning system where the frequency displayed is the frequency tuned.
It looks hard to remove the radio as well (from the pictures I've seen and things I've read on this site). But maybe once I have my V35 I'll bite the bullet and send the radio overseas to you (if I can remove it myself =P).
Cheers,
Matt
there's probably a clarion service centre in auckland anyway. I'm not the be all and end all for these things I simply do a lot of them and tend to muck around with electronics more than most.
I know of 10-12 guys on this forum alone that do what I do and they stay quiet about it. one of which repairs radios for a living.
O yep, that's good to hear.
(I'm sure I've read somewhere else on this forum that you said that the head unit wasn't actually made by BOSE though, it too was made by Clarion. Or am I imagining things?)
Because I would be getting a car with the BOSE system rather than just the standard system, but this is still a problem with the BOSE systems as well isn't it?
You can't really blame them hey Chris...lol! :rolleyes:
Anyways, hope you're well buddy.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
