I am wondering if the turbo experts here could offer their advice please? I have nearly finished my RB26 engine and the spec is as follows. What I need to decide now is the turbo(s) to use. I am after total manifold reliability in long distance circuit race usage, so tubular manifolds are not an option as I can't afford something with slip joints, in Inconel, and anything other will, to me, be suspect. I have 2 brand new HKS low mount cast iron manifolds for single turbos, and I have stock RB26 manifolds. I am not totally sure what material spec these HKS things are, so they may well crack, but I do have a spare and maybe access to a good used one as well. So I need advice what set up to run. I am looking for about 580 to 620 flywheel horsepower, with as little lag as possible, on UK pump fuel (98 RON), ad maybe more on race fuel for a bit of fun, with a second map. Engine spec below. Thanks.
New N1 block, new head ported and cleaned up casting. Steel crank, steel rods at stock stroke and 86.5 mm bore. Tomei cooling channel forged pistons, CR 8.5 to 1. A pair of Tomei 280 degree cams with 10.8 mm lift, SARD 700 cc injectors in modified stock rail, stock throttle bodies bored out to 50 mm with bigger throttle plates, Tomei oil pump, wet sump, external head drain assistance. ECU is a Motec M800, running closed loop with wideband. Fuel pump is Bosch 044 fed from a swirl pot.
Chassis is race spec RWD R33 GTS-t run as a 2 WD set up on slicks. Gearbox is uprated T5 dog box.
Thanks.
Just want to stress it's the cam duration that's worrying me, I think if I choose a turbo(s) with fairly small turbine size the back pressure versus the long duration may cause flow reversal. I went with 280 degrees so I could build something a bit stouter when I get bored with 600 FWHP, or decide to put it in a 4WD car. Thanks
What sort of race duration do you call long distance?
Have you checked out the fabricated manifolds done by Full-Race? High quality items, and sale of the HKS units you have would probably cover the purchase of one. Send them a message and find out. Alternatively speak with 6boost and get something direct from Australia - he has an excellent reputation. Either way you'd be getting away from cast iron if you have concerns about the HKS gear being able to survive circuit race use. They (HKS) might crack, but I doubt they'd fail.
Turbo-wise you'd best consider using an external gate setup. For the required power IMO it would be hard to beat a single GT3582, probably in 0.82A/R for a balance between lower rpm response and high rpm breathing capacity. I have nothing against twins, and there is plenty of experience on this board with the various GT2560 combos, but I think the single would lose nothing in terms of response and be easier to access for general maintenance/inspection work.
What is the targeted useable rpm range BTW?
Hi Chris , if it were me I'd use a pulse divided exhaust manifold like either your HKS cast RB26 manifolds or (IMO) the Rolls Royce - one of Geoff raicers (FullRace Motorsports in US) brilliant fabricated stainless steel ones . I know most will baulk a fabbed stainless ones but Geoffs ones are without peer . Don't take my word for it , search Full Races site and bash Geoff out some E mails .
Every performance turbo site I've seen in the US swears by FR's turbo manifolds , they may swear at the prices but very few question the results .
Ask him but I'm reasonably sure he'd suggest a Garrett GT4088R and has had a lot of success with them .
You get into a grey area with GT3582R's because there is no propper twin scroll turbine housing made for them - well not for the higher EGT petrol version of the GT35 based turbos anyway .
FullRace has used a turbo cobbled together by Turbonetics called F135R which you can see on his site but it's not a cash and carry from a local distributor here like the GT4088R is .
Geoff is one of the very few who has played seriously with single turbo RB26's in the US and I believe his opinions are well worth listening to .
Lets know where you go with it , cheers A .
Edited by discopotato03
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
