Prefered event
35 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
After a successful recent SAUWA karting event sponsored by Blacksun, we are now trying to work out what what you guys would prefer to do.
Obviously for both options the rules remain the same being your kart must have no less than 2 drivers.
So, would you prefer a 1 hour race with each person paying $100, or would you prefer a 2 hour race with each person paying $200.
There a pro's and con's to both and as soon as we get some feedback, we will begin to plan the next event!
Cheers
Brad
SAUWA Motorsport Co-ordinator.
https://www.sau.com.au/forums/topic/232592-kart-events/
  • Replies 40
X is relative to the amount of times Y goes into the sand in hour 2
I didnt get a proper vote here because I just hit view results so I will add another 2hrs vote on
You can't vote after viewing results for a reason.. FENCESITTER! :D
https://www.sau.com.au/forums/topic/232592-kart-events/#findComment-4096327
