Hey all,
Being my first import, there are things that I'm still unclear about, and I'm just looking to bounce some ideas off all y'all.
I have recently got a new dump/exhaust installed, and it's changed the power delivery. Before I had it installed, it seemed to have smooth delivery until redline, and when I had the boost controller on, it would pull like buggery till bout 5500RPM, and then sort of tapered off, not a complete died-in-the-arse situation, but just pulled less hard.
Now with this new free flowing exhaust, it seems to be doing similar thing, even with the boost controller off. Am I right in thinking that it's just my widdle stock turbo running out of puff?
https://www.sau.com.au/forums/topic/232636-flat-spot-in-33/
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
