Hey guys I have an r33 s2 with fmic, turbo back zorst, upgraded fuel pump, boost controller and a remap ecu.
I was watching my consult readings and on 10 psi foot down I get the following at around 7000rpms Timing at 53' btdc, injectors duty 93% afm 5.115v. are any of these reading high for such little boost? I didn't think the injectors were getting pushed so hard on 10psi!
Cheers
Russ
https://www.sau.com.au/forums/topic/232805-does-this-look-right/
I have cleaned afm and replaced filter like 1-2000ks ago so maybe the injectors need a check. I just thought I'd have more room to move on the boost side of things.
Also how is the timing does that look right.
Edited by RPR33
well the injectors arent even 100% yet, and then once they are you still need to make a bit more power to get the rich AFR up to a leaner/more dangerous level...so i wouldnt be too worried about it, of course a dyno, and further datalogging would help if you are concerned.
but AFM might be more of a worry given its closer to limit...do you then get fuel cut etc? i dont know what happens when u max out AFM.
also are these peak values? if so then they didnt all happen at same time...because no way ur running 50deg BTDC at full boost!
id be trying to use a stock ecu and seeing what it reads and then another afm, as yeah, i just had a look and my afm isnt that high on a r33 turbo on a bar on a rb20, and if thats lower, then maybee ure ecu is tuned stupidly or the afm is faulty and thats whats casuing the massive afm duty cycle
Hey mate I don't ever get fuel cut I think it has been removed eg: when I had my fmic installed the guy who hooked it up did not connect anything back into the actuactor, so I was hitting like 15-17psi (without knowing it) and no problems untill it shot off a cooler pipe!!!
I was funny the first time it boosted I was like wow that cooler makes it go heaps harder.... thinking I was still on 7psi haha
and yes they are peak values.
Russ
327.68 volts as far as consult data stream is concerned...but the AFM's limit itself - not sure...id have thought 5 or 5.2V
ecutalk will clamp AFM at 9.9 if it somehow reported higher
it may be the case that more air than whenever u hit max AFM volts is going in, but the afm keeps reading 5.1 so eventually the mixture may lean out. need to get on a dyno to confirm
yeh thats my thoughts 5.115 is max so anything above that will still read as 5.115v. she's rich as on the dyno running 12-13psi, also my timing was at 20btdc at full boost
I guess I just need an ecu upgrade or a remap.
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
