Gud dai People,
Names Elle, just joint todai. I own a 97 R33 which i imported about 7months ago.
Im down in adelaide, and enjoy cruising around and working on my car. fortionatly
i still got lots to learn, iv just decided im goin to start on mods for my car, starting
with Luks then power. Any iideas and tips wud be appreciated. also if you got any
parts for sale let me know via email [email protected] Luking forward too
getting to know every1 and learning new things !! :thumbsup:
ey welcome, ur looking for exterior mods? Best to start with the body kits. If you look around forum you can find good cheap ones. Once u got them go for rims, if u want, tint windows and little things like Aftermarket side mirrors. Once you have everything arrange for paint job. Get the paint yourself like i did i paid 160 for 5Litres and then try find someone on the forum in SA who can do the labour and spray the car. i got my whole car painted for $600 off a friend in preston (melbourne), too bad you live SA.
Thanx for the advice, so far been shopping around for a kit, but my pickyness aint exactly helping, that and the fact that i cant find a top secret rear bar..... mite have to give up on that idea :) otherwise everything seems to be comming together pretty well.. just gotta find the time to get it all together. Where do i find paint?? and how do i find my color code?? please to meet you btw :)
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
