yeah ive read that heaps of time, that putting in a metal shim style headgasket will give you better compression to run more boost. How much boost would u be able to run with metal headgasket and std internals? or even better how much in say an RB20 :D ?
  • Replies 105
Im assuming the reason so many RB25 owners often run thicker/aftermarket headgaskets is so they can dial in a little more boost as the lower compression ratio starves off detonation.
RB20s already have a lower compression ratio of 8.5:1 (vs R33 9.0:1) meaning that it isnt as common to see RB20s running thicker head gaskets in the quest to run more boost.
Im actually considering upping my compression ration if my engine needs rebuilding.:bahaha:
bbenny, its hard to say, just gotta get the car on a dyno and see what happens. Tuning, fuel, intercooler. plugs, etc - all make a bit contribution to how well the engine will handle boost.
On the subject of power to boost, a guy I know was getting around 230rwkw with the same turbo on an SR20 at 1.2bar.
1.3 bar was 240
1.4 bar was 250
1.5 bar was over 280,
so I am hoping for good things as the turbo gets up around the 1.5bar mark - time will tell.
bbenny, dont worry about dropping the compression ratio, or fitting a thicker head gasket.
My thoughts are the less boost you can run to make your required power the better.
For an RB20 i dont see 1.3-1.4bar being too much a problem on the street, as long as
- You stick to the factory rev limit (with your 2530, perhaps think about dropping it to say 6,800rpm)
- Your fuelling, engine cooling etc is keeping up.
- Proper care is paid to maintenance.
I say on the street as you are never really afforded the opportunity to sustain high engine loads for long durations.
If venturing out onto the circuit, i would wind a little boost out of it.
Lowering the compression will bring detonation higher in the rev range and thus you should be able to wind up the boost more without detonating in your car's rev range. But lowering the compression is also going to make off boost performance worse. So there's a tradeoff, like most things.
Steve, has the power curve been fixed up now so that power increases in a nice smooth fashion? Will be good to see the results at 1.5bar when the turbo is most efficient. When are you getting the head gasket done? You going to do cams too?
EVO, I am doing cams at the same time, I have 256/8.8in and264/9.0ex so hopefully will take car of the off boost response side of things. The crazy thing is, at the moment off boost is so much stronger than with the stock turbo its amazing. I put this down to a decent set of headers (tuned lenght, ceramic coated) and I am not sure if the front facing plenum is helping too, all up it is awesome. The car is just bloody awesome to drive, just wants to go hard:)
I may have to go a larger turbine housing if it starts to choke the top end, but I am keeping my fingers crossed.
Paul, cheers mate, so how is the GT30 coming along? I have decided that you guys will need to have a bbq when you come over for the drift day. Are you driving over? Would love to check it out:)
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
