  • Replies 50
As promised here are some shitty pics of the car in the garage,
pls excuse the mis matching wheel. mid way thru doing stuff..
also have not fitted the front skirt yet. its going to be black...
the color changes in different photos and it is hard to get a treu representation of the color but here is a coupla shots..
notice the front lights have been pulled apart and the housings painted black, the indicators are now clear and the front bar is stealth... i am not into fulleh sic...
let me know what you think..
Very nice shade, congrats. I really like the way you have kept the mods clean, as i too hate "fully sic" mods. Where did you get the paint done if you dont mind me asking?
It was done at S&K panels in campbellfield. and was VERY cheap. $1750 and that was using Sikkens paint.
this included repairing 2 major dints and dozens of pin dents. the quality of the paint is fantastic but there were some things i was not happy with,
1. they put my door lock actuator rods in backwards so when the window went up or down it fouled on the rod and went CLUNK...
2. they left the windows of the car down during the whole process and the car was FILTHY inside when i got it back...
3. one of my door trims was marked...
but i the paint is fantastic. just their assembly was a bit rough. cant complain for that price seeming as the paint alone was over $600 and it only took 3 weeks from drop off to pickup.
Thanks for the info and the heads up. That sounds really cheap, even including the incidentals you mentioned ! I might check them out.
well this has all gone to s**t, the car turned out not being able to import so i',m back to looking, pretty sure i found one thats white so i wont be changing the colour for now.
What stopped it from being imported??
Damage/rust or something else??
Very nice. Make me want to strip mine back and paint it again..... :)
it was to do with the date it was made, goes by chasis numbers or something as well, apprently out by 2 numbers or something
Edited by nvsA4
pretty much the guy in japan told the guy i'm going through it was all good but yer it was 2 numbers off :down: if it was bulit a few hours later i would have it by now, Me and the guy im going through arent out of pocket any money so i guess i'll just have to wait again
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
