Not interested in full comprehensive insurance ATM - too expensive. Anyone have 3rd party fire and theft? i've tried a few places with no luck. famous dont offer it. Just cars only insure for $4k, and i'm waiting for a reply from shannons. I am yet to contact unique or elders (only just found out about them).
I'm 20. 2.5 years driving under parents name, no accidents, no fines etc, looking to insure 3rd party F&T, s14 200sx @ market value.
sorry if this has been posted before. i searched and only found any decent info for full comp insurance. cheers
Yeah, I haven't heard of full fire and theft being offered (for less than you'd pay for comprehensive insurance) either.
Buy a really, really good alarm system and insure yourself with Just Cars. At least the $4,000.00 will cover your stereo, rims, etc., which are probably more likely to be stolen if you're careful where you leave your car.
hey,
i have 3rd party with just cars. i'm 20, on my P's, no accidents or claims (hell not even a speeding fine!), and i pay about 400 - 450 a year (can't remember exactly).
fire and theft is an extra 300 if u can afford it.
i don't see the point paying 3000pa for insurance when in 5 years you have paid for another car!
then i spent some $$ on an alarm and clublock and presto - car ready to park at broady...!
Comprehensive insurance also covers hail damage and if an uninsured driver hits you.
Even with the best alarm system on the planet AND comprehensive insurance, there are some parts of Sydney I wouldn't park my car, this Skyline just owes me more than just money :)
T.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
