  • Replies 58
For those that want to know Mark Tilbrook now works with us at Willall Racing. He is an integral part of our R35 development program, and also responsible for the assembly and maintenance of our existing Skyline customer base :D
Edited by Martin Donnon
I can't comment about Steve's & Craig's experience with Brady but I found him to be a straight up guy who was very helpful and reasonably priced.
I suppose it doesn't matter where you go, everyone has varying experiences.
For those that want to know Mark Tilbrook now works with us at Willall Racing. He is an integral part of our R35 development program, and also responsible for the assembly and maintenance of our existing Skyline customer base :)
Awesome, i think i'll be giving him a call soon about fitting my turbo's, i've been taking my car to Mark for the past 4 or more years and he knows what he's on about when it comes to skylines, he's the main reason i now have an RB26 in my car, he even did all the shopping around to get me a good deal on a motor, he's a top bloke and always a good laugh when Mark's around :/
Can anyone tell me if Felicity Tillbrook is related??
Dunno, but feel free to have a crack:
Your Search:tilbrook, f, south australia. Results:1-3 of 3 listings found.<h3 class="sectionLabel"> Search results</h3><h2 class="nameDetails">Tilbrook F</h2>(08) 8244 5357
17 Thain Ave
Findon SA 5023
spacer.gifShow map...<h2 class="nameDetails">Tilbrook F & B M</h2>(08) 8261 0291
136 Fosters Rd
Hillcrest SA 5086
spacer.gifShow map...<h2 class="nameDetails">Tilbrook A L & Bacalso F T</h2>(08) 8298 8673
28 Karoona Crs
Seacombe Heights SA 5047
17 Thain Ave
Findon SA 5023
136 Fosters Rd
Hillcrest SA 5086
28 Karoona Crs
Cheers Damo, I think I might!!
A Felicity Tillbrook got a petition started back in 2007 to get a drag strip back up and running in SA. I have come across it and woken it up :) Just need to talk to the person who started it all..Felicity Tillbrook!
I know Mark when I lived back in SA..but cant remember the girls names :O
17 Thain Ave
Findon SA 5023
136 Fosters Rd
Hillcrest SA 5086
28 Karoona Crs
really damo thats not the smartest thing you have done you shouldnt have done this
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
