Hey all,
As the topic title says, Nige from the FM104.7 breakfast crew bought himself a black Auto R32 Gtst some time ago with the intention of turning it into a drift car.
However his dream was cut down yesterday morning as the R32 was stolen while he was on air doing the show. :O
We all know how much people get attached to their Skylines (I know I am) so if anyone has any information or sees a black R32 Gtst with stock rims, Jax Quickfit and Federal Tyres stickers on it getting around Canberra or surrounds, make sure you contact myself and I will call Nige or contact the radio station immediatly.
P.S. If anyone sees a Black R32 Gtst for sale for cheap (or parts) please let myself or Nige know.
You can call the radio station on (02) 6242 1047
Pics to come...
https://www.sau.com.au/forums/topic/233507-r32-skyline-stolen/
I dont think it was taken from the radio station, he usually drives his Magna to work... I think it got taken from outside his house.
By the way the rego is - BEB 13G
Also if anyone knows of a cheap Manual R32 Gtst for sale please let me know. :O
Well... from Mick's post in the spotted thread, I realised I MAY have seen this car yesterday morning.
There were two males in the car. The driver had black hair about 6-7cm long which was either straight or slightly wavy, and stood up off his head (nearly like a fro, but they didn't look african american, looked more lebanese/similar - something with a fairer complexion). They both had a fairly dark tan or natural complexion, the passenger looked very similar, possibly shorter hair, or shaven head. Not much info ... hopefully helps though. Please note I hold no particular thoughts as to skin colour etc, just doing a 5h1tty job at describing what I saw... I hope these ppl are caught if it WAS indeed them.
I didn't catch any other detail as I was turning across the intersection and couldn't gawk while turning (plus, the car looked pretty 'plain-jain', so maybe I didn't pay too much attention, other than wondering if they'd seen me wave (twice)).
Great news!
This morning Nige called me to let me know that his Skyline has been recovered by ACT Police! :wub:
Apparently the idiot who stole it, took it to a wrecker (who had nothing to do with the theft) and asked him to strip the car so that he (the thief) could use the parts for his own R32 Gtst...
The wrecker thought that it was suspicious that someone would ask him to strip a perfectly good car and called the police, however he had already pulled nearly everything off or out of the car beforehand.
The thief has been aprehended and Nige will be reimbursed for any damages or loss.
Thanks to all who kept their ears to the ground and an eye out for this car, it is much appreciated! :(
Cheers :P
Mick
