Hey all,
As the topic title says, Nige from the FM104.7 breakfast crew bought himself a black Auto R32 Gtst some time ago with the intention of turning it into a drift car.
However his dream was cut down yesterday morning as the R32 was stolen while he was on air doing the show. :O
We all know how much people get attached to their Skylines (I know I am) so if anyone has any information or sees a black R32 Gtst with stock rims, Jax Quickfit and Federal Tyres stickers on it getting around Canberra or surrounds, make sure you contact myself and I will call Nige or contact the radio station immediatly.
P.S. If anyone sees a Black R32 Gtst for sale for cheap (or parts) please let myself or Nige know.
You can call the radio station on (02) 6242 1047
Pics to come...
https://www.sau.com.au/forums/topic/233507-r32-skyline-stolen/
I dont think it was taken from the radio station, he usually drives his Magna to work... I think it got taken from outside his house.
By the way the rego is - BEB 13G
Also if anyone knows of a cheap Manual R32 Gtst for sale please let me know. :O
Well... from Mick's post in the spotted thread, I realised I MAY have seen this car yesterday morning.
There were two males in the car. The driver had black hair about 6-7cm long which was either straight or slightly wavy, and stood up off his head (nearly like a fro, but they didn't look african american, looked more lebanese/similar - something with a fairer complexion). They both had a fairly dark tan or natural complexion, the passenger looked very similar, possibly shorter hair, or shaven head. Not much info ... hopefully helps though. Please note I hold no particular thoughts as to skin colour etc, just doing a 5h1tty job at describing what I saw... I hope these ppl are caught if it WAS indeed them.
I didn't catch any other detail as I was turning across the intersection and couldn't gawk while turning (plus, the car looked pretty 'plain-jain', so maybe I didn't pay too much attention, other than wondering if they'd seen me wave (twice)).
Great news!
This morning Nige called me to let me know that his Skyline has been recovered by ACT Police! :wub:
Apparently the idiot who stole it, took it to a wrecker (who had nothing to do with the theft) and asked him to strip the car so that he (the thief) could use the parts for his own R32 Gtst...
The wrecker thought that it was suspicious that someone would ask him to strip a perfectly good car and called the police, however he had already pulled nearly everything off or out of the car beforehand.
The thief has been aprehended and Nige will be reimbursed for any damages or loss.
Thanks to all who kept their ears to the ground and an eye out for this car, it is much appreciated! :(
Cheers :P
Mick
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
