Sorry to ask this but just so I don't get lost. Which street is the entry to the underground car park? Wellington?
you can either go that way and through the lights or turn off walter rd at the entrance across from maccas
  • Replies 140
hey..
i'll try make it there, is it kool if i bring a 180sx,a soarer, and a wrx along. they all members off skyline aus also.
any idea how far we coming down south, as in near murdoch/canningvale area?
thanks niran
hey..
thanks niran
as long as the owner of the soarer's name is not john :bunny::)
Edited by MeLSki
Hey Guys,
My names Benson i drive a Magna - Plates [ STEALTHED ]
Im New to SAU I dont Own a Skyline but will be buying a R33 Shortly you All dont mind if i come along for this cruise and
get to know some of you and your cars :laugh:
Hey Guys,
Course we don't mind! I was in your shoes and I just boguht my new baby 33 this week!!! So come come, Krystal's made it an open cruise anyways :D
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
