  • Replies 518
omg no wai
Congratulations, you're currently a silver member, silver being 15 stamps or more. As a reward we’re offering silver members an extra, post-sellout chance to get special Field Day souvenir tickets. Quantity is very limited so it’s first come first served.
too bad i already have my tickets:p
Field Day time up yo!
KILLER STAGE
1.00 Mark Murphy
2.00 Busy P
THEN CENTRE
2.30 Eric Prydz
4.00 DOOM AND Hodratt
4.30 Santogold
5.15 A-Trak
LEFT FIELD
6.30 Late of the Pier
Back to centre
8.15 Boys Noize
THEN KILLER 9.30 for SWITCH!!!
shore thing is too overpriced and fails to deliver IMO...
went and saw basement jaxx and bob sinclair years ago... youd think a 6 hr festival they would each play for 3 hours..
but no some shithouse dj was mixing till midnight then they only played for 1.5hr each..... then it ended at 3am... wtf are you meant to do then!
Ill be partying all night and morning at my mates house party in rose bay NY then backing up to field..... really do my liver some damage!
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
