Was curious how much power can be made using the standard head and cams, reason being that im going to rebuild my motor so it will survive some higher boost and was wondering will the standard head flow good enough to see some good power readings with out dropping valves or other nasty things.
ie, a standard head is good for up to 280 atwkw
or, my head dropped all its valves into the pots and the world ended at 350 kw with a loud bang followed by some rattling until all was quite bar the trickling sound of coolant on the garage floor.
Thanks for any info guys and girls.
MLR
https://www.sau.com.au/forums/topic/233609-stock-25-head/
270rwkw/17psi (dyno Dynamics) GT30 (600hp) on PULP
370rwkw/24psi @ Autosalon (mainline dyno), GT30 (600hp) on Sunoco 104 and LOTS of extra timing :P
Everyone always said my set-up felt great when in the car. So i dont think i was lacking by having a stock head/cams at all.
Certainly was quick and did the numbers. Boost was on ~4000rpm @ both levels.
https://www.sau.com.au/forums/topic/233609-stock-25-head/#findComment-4095483
+1 for twincam 30 :)
My 25DE head made 365rwkw in its' previous life through standard intake manifold, standard throttlebody and standard cams.
that is sick! I cant wait to get my cooler welded so i can retune the focker
Stock 25de head on 3ltr making 260kw at the moment, plan on getting it to the mid 300's :bunny:
https://www.sau.com.au/forums/topic/233609-stock-25-head/#findComment-4098747
Yeah we figured the throttlebody was the limiting factor there, it just wouldn't make anymore power.. that was at 22psi through a pair of 2540's.
I'm going custom forward facing, q45 throttlebody and GT35R.. might chirp 2nd :)
https://www.sau.com.au/forums/topic/233609-stock-25-head/#findComment-4098776
haha yeah thats pretty much what i have at the moment but stock tb, thinking of changing it to a custom billet one in the near future though...
In a 32 you wont even use second mate, I am frying 2nd in a R33 with fat stickies on the back @ 260!!! 3ltr torque FTMFW!
Edited by dano4127
https://www.sau.com.au/forums/topic/233609-stock-25-head/#findComment-4098823
^^ that would probably be the 2540's more than anything... such a nasty turbo :blink:
Nah same turbos are on the new motor (30 with a 25T head, greddy plenum, q45 t/b) and making 540awhp at 1.4bar (~20.6psi), so it was definately something on the intake side that was restricting it.
Dan, that's what I'm hoping for :)
Edited by bubba
https://www.sau.com.au/forums/topic/233609-stock-25-head/#findComment-4099175
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
