first i sanded the parts with wet and dry sand paper by hand. i used three different grades, i think they wher 800 through to 1200. them use a stitch cotton mop(buffing wheel) on a bench grinder,(has to be at least an 8inch) use the stitched mop with a brown buffing compound. then once you get a shinny finish u use a different buffing mop(loose leaf) with a white buffing compound. and u can get it a shinny as i did.
u also need a spindle (adaptor) for the buffing wheel to fit on a bench grinder.
guys remember this takes hours to get the result that i got.
8 hours to do the rocker(cam) covers.
6 hours to do the intake pipe.
1/2 hour to do the CAS
and about 9 hours to do the plenum.
and this is only polishing time. not removing or fitting parts back on.
r31 skyline chick
ur plenum looks really good, who did you get it done by?
i was thinking about going in to business for myself and doing polishing full time. what do you guys think.
how hard will it be to mainttain that shine ? coz im getting my intercooler piping re-done in stainless so looking to shine up the engine bay... im willing to spend time into it, i dont have a bench grinder, rekon there's any other way for me to do it ?
DJ_L3THAL
i wipe it over every time i wash the car and give it a light polish by hand about every 3-4 weeks and still looks as good as the day i did it.
deffinetly cant do it unless u have a good bench grinder!
you wont even be able to use a angle grinder because u need the loose leaf mop to get the best shine. you could always do it by hand, but you would have to do a lot more sanding, and it would take you an eturnity.
Originally posted by walkoau
r31 skyline chick
My other half does all my polishing.
And my metal fabrication, and all the other fun stuff that I can't do by myself.
I do the painting and ricing and cleaning.
I think it's fine.... as long as you don't mind getting dirty.
It's probably not as viable as it sounds.
Some things can be an absolute bitch to polish, my plenum has at least 8 hours work in it, and it still isn't perfect.
You need to take into account that if something so small takes a whole day to do, will people be willing to pay you a whole days wages just for one little shiny bit?
r31 Skyline chick
yeah iknow what ur saying, but i dont mind getting dirty, im a heavy vehicle/plant mechanic by trade so im always dirty anyway.
DJ_L3THAL
i have no idea how much a pro would charge to do it. id imagime it would cost a fortune, but they would have all the right gear and get it way better then mine.
also i personally dont like the blue on my hose and wiring! i want to purchase some blue silicon hoses to replace the black one and get rid of the blue plastic.
rb20-calais
pm me. let me know when you want it done. if you can remove and refit ur self?
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
