Personally i hated hicas, im so much happier with it gone and i harly ever drift. So much more predictable round corners. And yes it is a must if you drift the car! The hicas will try to make you go straight the whole time instead of sideways :laugh:
It can be done with hicas, gets a bit hairy when goin hard and particularly if its a bit wet.
Lots of corrections and in my opinion not worth keeping if your seriously considering the drift.
Mine is a R32 but I know I hated the stuff. I mean its a sports car of sorts and why the hell does it need a driving aid.
Got rid of it and actually think it has improved the handling. More predictable and I think quicker due to the fact as now I know exactly when slip will happen rather than there she goes-oh sh*t there she goes again.
i still got mine and try to slide. when i 1st started i thought hicas was shit and it was making me oversteer etc.... then i realised that finding a smooth rd is one of the more important things. plus if its a r32, hicas is minimal, i remember reading somewhere that hicas on r32's only moves out like 1.5 degrees, which aint much, and unless your doing 120k entries you shouldnt worry about it to much...
in saying that, i still plan on removing it in the near future.
HICAS never made me spin out but it certainly made the car feel rather dodgy and when doing big 2nd gear burnouts it was hard to change direction as the rear wheels started pointing in the same direction as the front wheels so all it wanted to do was crab down the road.
HICAS was removed by the time I got around to some skidpan drifting so can't comment on before and after.
So thats why it does that when doing burnouts!! Everything makes sense now lol.
Edited by PM-R33
HICAS is always used as scape goat for crap driving but it does make the car feel squirelly....certainly wont make you lose it but at the end of the day predictability is what your after so best bet is to bin it.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
