i have a dayz kit and would love to get that little lip extension for the front bar. anybody know how roll cages go in a daily driver, im pretty sure u will get defected for that.
in south australia half cages that dont come past the back of the front seat are legal as long as you dont have any passengers in the back
not sure about other states
if you can get these eyelids for same price, ill take a set http://page12.auctions.yahoo.co.jp/jp/auction/p119737283
pass on momo wheel, almost half that price thru importmonster
D.
do you realise they are not painted aswell they are just made of black resin not fibreglass
is this what you mean?
or this
Edited by piratewake
dont really care what they're made of or if they're painted (my car's white anyway), just want that exact style of eyelid
D.
D.
i can get the style you want $120 unpainted or $190 painted and thats delivered
mmmmm that vented hood will look nice on my white s2.... i'll hit u up a little later
oh now i see a defuser ... hm.... any rear defuser ? ... price ?
Edited by RBPOWA
front defuser $750
rear defuser $900(bottom pic is just an example)
put me down for a set of unpainted please... when do you need cash?
D.
D.
asap
let me know when you have the money and ill pm you my details
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 😛 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
