i have a dayz kit and would love to get that little lip extension for the front bar. anybody know how roll cages go in a daily driver, im pretty sure u will get defected for that.
in south australia half cages that dont come past the back of the front seat are legal as long as you dont have any passengers in the back
not sure about other states
if you can get these eyelids for same price, ill take a set http://page12.auctions.yahoo.co.jp/jp/auction/p119737283
pass on momo wheel, almost half that price thru importmonster
D.
do you realise they are not painted aswell they are just made of black resin not fibreglass
is this what you mean?
or this
Edited by piratewake
dont really care what they're made of or if they're painted (my car's white anyway), just want that exact style of eyelid
D.
D.
i can get the style you want $120 unpainted or $190 painted and thats delivered
mmmmm that vented hood will look nice on my white s2.... i'll hit u up a little later
oh now i see a defuser ... hm.... any rear defuser ? ... price ?
Edited by RBPOWA
front defuser $750
rear defuser $900(bottom pic is just an example)
put me down for a set of unpainted please... when do you need cash?
D.
D.
asap
let me know when you have the money and ill pm you my details
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
