Sand blasted the front gaurds at work yesterday, glassed, bogged and etch primed today. Tomorrow it's the sills. Someones already done a poxy bog job on them in the past so i"ll have to grind it out, rust treat it and more glassing. Got given a GTR XU1 boot air dam and guess what? it fits quite nicely strangely enough. The curve is so similar to the 210s boots curve that it won't take much to have it sit nicely. I'll put up a pic at the end of the day. Not sure what colour to paint it, the car will be white and the cooktop light assembley will be changed from grey to white also. Should i paint the dam white or black?
https://www.sau.com.au/forums/topic/233773-210-body-restoration-under-way/
Sometimes the rust has just gottta go. Thankfully I work with some very generous sheetmetal workers.
This area had been badly bogged, thus the rust had a field day. Now it's been rust treated and sprayed with zinc it. The new sill will be welded in with a bit of glass and putty on the sides.
The sill in, Wish i had more room. Having to stack doors (bloody heavy too) on the boot, they must weigh about 40kg each. shame you have to have them,love to replace them with fibreglass and hope never to get hit side on.post-44326-1220689133_thumb.jpgpost-44326-1220689133_thumb.jpg post-44326-1220688909_thumb.jpg
post-44326-1222083122_thumb.jpgpost-44326-1222083297_thumb.jpgpost-13170-1124441726.jpg
Started the main priming stage today. Did the bonnet,boot,and guards in etch primer and put a coat of filler primer on this avo. Typing this with red raw fingers,bloody sanding aahhhh
Looking good man, nothing worse then sanding back a car, then priming, then sanding, then painting, then repeating :)
Dreading repainting mine, but liking some of the pearls on ebay at the moment :)
Cheers Dan
Primer filler on, my wife has the worst headache ever from fuming. :) Guess you gotta take the good with the bad. My mates compressor worked itself so hard it hemoraged oil. I think a bigger compressor for the top coat will be required
Without cutting anything a 205/55/r15 will go under there with no worries.
I remember that V8 skyline man ran 17's on his C210, but I don't know how much work it took to make them fit.
Yeah VSPEC32, that's exactly what I'm after. I don 't like my chances of finding them here in Aus. The guy who gave me the air dam also has some A9x bolt on guards and I'm going to check out how they fit and look on my 210. Has anyone seen these overriders for sale anywhere? Ricky.
Have you considered buying from Yahoo Japan Auctions?
I've previously purchased off of there via Slidewize Imports who provide a service whereby you specify the maximum bid on an item, and they provide a calculation on getting it to your door. They then bid on the item for you, have it shipped to their depot in Japan, repackage if required and ship to your door in Australia. I did this with a tail light cluster for a 200ZR Fairlady and that landed within 10 days at a cheaper rate than buying from Victoria. Also used them to buy an R34 GT-R drivers seat for my Silvia.
http://www.slidewizeimports.com/
It mentions in that article that he uses S30 ZG Overfenders (possibly modified to suit), so based on that this search would certainly be of some assistance:
http://search.auctions.yahoo.co.jp/search/...0Z&auccat=0
Hope that helps.
Cheers
Brendan
VSPEC thanks for the info, I'll try the A9X over riders first and if no joy there I'll try slidewize.If any W.A members no of a decent rear bumper, I'd like to know otherwise I'll rip the chrome of and paint it white.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
