Due to my "collection" of GTR's and Turbos - I have a handful of these for sale:
Brand New GTR Garrett Performance Turbo Cores.
These are a great upgrade or replacement for your fragile (or allready broken!) ceramic turbo cores – turning you exsiting timebombs into more reliable, high-performance, higher boosting turbos.
They run 360 thrust bearings allowing greater reliability at higher boost levels. These turbo cores use all new parts (not reco) all you will need to keep is your compressor and exhaust housings.
Each core includes:
BRAND NEW Bearing Housing
BRAND NEW Steel Turbine / Shaft (Steel)
BRAND NEW Compressor Wheel (STD or N1)
BRAND NEW Bearings
BRAND NEW Circlips, seals and spacers etc.
Full Dynamic and Air Balance
I have seen 300kw on these cores on a near to stock RB26
(I have 2 types of cores – with standard size comp wheols OR with N1 / -7 Spec comp Wheels – using the later will require machining of your standard housings).
Price: $1000 Pair (FIRM)
(thats less than half that of buying a set of n1's or near half that of having your stock turbos being built to the same specs)
Contact: [email protected]
(Pic for illustration only)
Thanks for looking!
Edited by Antimatter
  • 1 month later...
