Which car was yours?
http://www.skylinesaustralia.com/forums/1-...h-t233992.html#
T55 in lane 5.
monga: what tyre pressure would you recommend? I had it down to 32psi all round.
I think that the rear tyres needed a bit more warmth in them as well. After the last pass the rears were picking up bits of loose gravel, after the first three they weren't.
  • Replies 109
Posted Images
I'm probably going to head down either next week or the week after to see what my car runs before it comes off the road. Anyone else want to reprezent with me?
Bubba if your keen to go on the 17th I'll come, My work shift will get released next week so cant confirm til next week but.
Need to give it a nice fang before I head to Tokyo, then when I'm back I can compare how new rubbers, wider wheels, and possibly a few more minor bits and pieces make the PB better. :P
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
