hey, just bought a rb25det turbo and when i compared it to a spare 20det turbo it looks pretty much the same. the only difference I could see was that the compressor housing was twisted around (it was setup for a 180sx top mount)
have added some side by side photos, so hopefully you guys can tell me it is a 25det turbo and not a 20det :)
the numbers have been ground off the compressor housing so visually it's hard to tell.
there is a way to tell. take the elbow off that turbo and see if it bolts onto your rb20 turbo. if it does it is an RB20 turbo. if it dosent it is an rb25 turbo. cheers
RB25 doesn't have the pressure feed on the comp housing for wastegate actuation - there shouldn't be a fitting there.
RB25 housing is noticeably (visible to the eye, and measurable) larger in cross section which means it has a larger A/R and flows more.
RB25 compressor impeller is larger in all critical dimensions - inducer and exducer. That means as you look into the throat of the compressor, it will look bigger. Verniers should measure up the throat larger too. If you pull the comp covers off you will see very quickly.
Looks like an rb20 r32 to me.
As Dale FZ1 said "RB25 doesn't have the pressure feed on the comp housing for wastegate actuation - there shouldn't be a fitting there".
Was it a reputable seller?
ok gay lol, looks like its a rb20det turbo as the turbo elbow bolts up to my spare one
and i bought it off my friend as he was told it was a rb25det turbo
don't go off the vacuum line fitting on the compresser housing, when i've put rb25 turbo's onto R32's i've tapped a hole there to bo able to do this, so i'd think that other people would also do this. the two turbo's are almost identical in physical size so the only way to really tell is to pull off the compressor housings off both turbos and compare the compressor wheels, the RB25 one is slighly larger.
or do what CEF11E has said, the RB20 turbo elbow wont bolt onto a RB25 turbo without modification, and even then the flange face on the elbow is smaller than the flange face on the turbo.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
