Hi!
I was offered a nice 3row 52mm alloy radiator for a good price.
And wanted to know if there are any real life benefits vs running a more common 2row.
Anyone running 3row one on their r32s/a31/s13 ? How well does it work with the clutch fan ?
Thanks!
Hi!
Thanks!
Hi Robots,
I actually build alloy radiators for a living, here's my thoughts.
I like big tubes, The wider the tube the more fin contact and the more heat gets pulled out/dissapated I would rather go with 2x27mm tubes over say 3x19mm tubes.
I dont like 3 row cores, All our cores are 2 row 57 thick, Which is 2 tubes at 27mm thick.
Our radiators will NOT work with the standard clutch fan, though, It's just too thick. I think a 42mm would be best for a street driven car that gets a bootfull every now and then.
Thanks,
Scott
Remember that a radiator needs air to flow through it to work properly. The factory shroud and clutch fan is a very effective setup and sucking air through the radiator.
There is a lot of work to ensure good flow of air if the shroud is not used. I would recommend staying with a good quality 40mm radiator which enables you to retain the factory shroud and clutch.
Hi Robots,
Thanks,
Scott
If your radiators dont work with standard fans, then waht do you use that works?
At a guess, thats up to the individual, he just builds the radiator :P
I have heard from a few people that have gone to AM radiators with electric fans that they have had overheating issues. That clutch fan and shroud is dam efficient! Takes forever to get to operating temp when bleeding the system. Ha.
Like was stated, for street driven/occasional track use the thinner core (which fits standard shroud) is good.
The larger core would probably be aimed at higher output engines, in which case they are probably using high quality thermofans and shrouds to suit, (not like some people I know who bought 2 fans from supercheap and cable tied them to his radiator).
Thermofans can work well when they are setup correctly with decent gear. For what it's worth, the EL-AU falcon thermo fan setup is a decent setup which can be sourced relatively cheap both brand new and 2nd hand.
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
