Item: Various items from the toilet
Age: You don't want to know :down:
Condition: very bad :)
Price: I'll pay you to get rid of them!!!!!!!!!!!!!!!!!
To Fit: (What car) not a car, more so..... a bin
Contact: I would rather you don't "contact" me
Comments: this is just a joke....... I am in a silly mood right now (not to mention stone drunk) . Sorry for the buyers out there looking for a bargin. Just chill if you are offended.... :(
https://www.sau.com.au/forums/topic/234298-cleaning-out-my-toilet/
ill take that half roll of toilet paper and extremely used looking toilet brush with the stains :(
hahaha :laughing-smiley-014:
Sorry, the "half roll" is actually just a cardboard roll now. I have an offer for it already but I am not sure if you can match it... Current offer.... 3 cents.
If you want, for an extra $2 I can clean the toilet brush to make it as good as new.... perfect for all the scrubbing required under the rear gaurds after the burnouts!!!!!
Come on guys, heaps of "bits" left!! Make an offer!!
Do you always go on shopping sprees for car floor mats when your 'stone drunk' :(
Um....
These floors mats are for the "said "toilet" (I need to make the toilet more comfortable).
You need good quality mats when you are "preforming"!!!!!
cardboard roll mine!!! got a hot lil 5c coin ready!!! noone can outbid my buying power muaahahaha
hmmm 2 buks is a lil steep for the brush. how bout it not cleaned??
Roll won to the man with the hot asre R33 with twin pipes!!!!!!!!!!!!!!!
I guess $2 is a bit steep. If you want it not cleaned I can post at $75 cents uncleaned (But be warned........ you will get funny looks when you pick up from the post office).
YAY I WON A WELL NEEDED ROLL!!!
all i need now is that cleaner...
hmmm ill take it for 75c uncleaned. and if they give me looks i will have to scrub their face!
:wub:
:wub:
I'll tell you what. I will sell you a good use toilet brush from my in-laws house!!
it is 20 years old but in good condition (much like my GTR)
You can have it for 65 Cents + GST (EFT only please)
Is that cool with you?
hmmm u drive a hard bargain but i will have to accept... any pics??? lmao
well m8 im out. have a good night and hope someone else starts playing along.
gl with sale :wub:
gl with sale :wub:
Thanks for playing along.
Its great to see someone with a good sense of humour...
Peace out............
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
