How long is a piece of string? If it is just for a set of speakers, and you have no plans for anything bigger, 8 guage is probably ok. If you plan yo go to subs, 4 guages is you best bet, install once keep happy. you will need to run rcas from the head unit and a trigger wire. A fuse holder is the same weather it is 4 or 8 guage, so its just a matter of if you want to fork out for the bigger wire. In a 33 is is quite easy because you only have a matter of metres to get to the battery. A metre tops is probably all you will need. Remember you will need speaker wire to get back to you fronts as well. If you are doing it yourself, $50 - $60 as a pretty much top guide, depending on where you mount the amp. if you get it done pro, you could be looking at over $120 mark, if they wire speakers and all for you. This method usually leads to a longer life span due to less stress :D But if u have a little knowledge, this job will be quite easy.
https://www.sau.com.au/forums/topic/23448-wiring-up-amps/#findComment-507053
if u dont do it urself, go to a proper pro
ie. not JB , strathfield or autobarn
i had my first amp install done by strathfield, i gave them good wires etc. they used shitty wires cos they couldnt fit it and i only knew what happend 1 year later cos i had no idea about car audio then. (they used 4GA from the battery like i gave them, then as soon as they got under the carpets, used 16GA to the amp, yes 16GA..not 8GA, no dist block or anything)
i ended up ripping everything out, doing it properly, which u will too later down the track im 99% sure
https://www.sau.com.au/forums/topic/23448-wiring-up-amps/#findComment-507260
We're getting a tad carried away here. Running a single Alpine amp is not going to require 2AWG cable.
As for the cable itself, much like everything else, you'll pay for quality. Realistically for wiring an amp up, including the speakers etc will set you back between $130-$200 for brands like Stinger and Phoenix Gold and between $250-$330 for brands like Streetwires.
JR, you asked where you can get 2AWG from? I can get it for you from any of the above mentioned brands. I use 1/0AWG in my own S15. :D
https://www.sau.com.au/forums/topic/23448-wiring-up-amps/#findComment-519378
2gu wire is not rare if u are in the electronics field, the thickeir the wire the more power that the amp can suck out, prehapes 2gu on this set up is to much , bit still i would recommend it, i have 2 gu running my kicker Amp.
Also what is equaly import is the wire running from the amp to the speakers. seen so many people buy good quilty wire to the amp from the battery, but have thin wire running to the speakers.
i paid $30 dollars a meter for my wire from the amp to my subs from stinger.
https://www.sau.com.au/forums/topic/23448-wiring-up-amps/#findComment-520165
use the calculator on www.caraudioaustralia.com
if ur feeding 1000rms over 5 metres, ur gonna want more than 4Ga.
otherwise ur probably not getting the full potential of ur amp.
go to www.caraudioaustralia.com then tutorials and have a look if u dont beleive me
https://www.sau.com.au/forums/topic/23448-wiring-up-amps/#findComment-523412
Hey guys
Even thowe im new to this skylineaustralia forum. i still know my fair share of car audio knowledge. First of all find out what amp rating fuse's are being used on the amp. What type of amp class is the amp? mono block ect ect ?. Wonce you find out what the rating is of ya fuse, then you will be able to make a good choice on what gauge cable you should be running, and keep in mind if you are going to upgrade your system in the near future it may pay to spend that little bit more and go a bit thicker. The run of length of wire you use will also play a big part on the sive you will have to get. I am currently running 0 gauge and i everything is fine, but rember as soon as you go up size's in wire componet's like fuse holders, get expensive so just keep that in mind.
hope that helps :D
shaun
https://www.sau.com.au/forums/topic/23448-wiring-up-amps/#findComment-538044
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
