Thanks Erik,
the car is just:
cat back 90mm
k&N filter
turbosmart type2 BOV
bleed valve running 10psi
and SAFC II
still have the miss problem though, so i know what im upto this weekend. will have to sort out if its the coil packs or the ignitor module or the plugs :)
i will be at pool place this thursday night, may see you there.
Nate
I don't think Genie's dyno is as bad as everyone says.... When Xspeed had my car and took it to Genie to dyno as part of the tune I got 285rwhp on the Genie Dyno.... At our SAU dyno day at SST my car pulled 284.4 HP.... both are very close results to each other....
Brett, I agree, but the real issue is they they still have correction factors, which means if they want to see a big difference, then they can make it happen. SST and one other place has had there correction factors removed, and there dyno figure can't lie.
Originally posted by hks-s14
Change your plugs to NGK BCP6ES coppers...they rock.  Steve put these into my car when I developed a miss whilst he was tuning it, my iridiums could not handle any more than 200hp, the NGK's fired perfectly up to 260hp.
what did ya gap them to ?? 0.8mm yeah
well... its believed that the miss may be caused by a AFM!
im heading down to cypher on saturday to see if i can swap one over...
i have checked the coil packs, and they all read 0.7 ohms across the pins, and plugs are fine.
so its either the AFM or the ignitor module... i dont know... its all too much!
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
