Well Mario the great man came down to Sydney for a spin around to detail some cars lately and I had dibs on a spot. Ive never seen a person so picky for perfection, thanks for all your effort!
Now as they say.. A picture is worth 1000 words..
Bonnet took awhile as it was quite bad (damn nasho) Please disregard the bonnet chips.
50/50 shot detailed on the right side.
Close up after bonnet done
Before - Boot and wing shot
After - Boot and wing shot.
Before - Door shot (drivers)
After - Door shot (drivers)
Done
At this stage the car protection is setting will snap some out in light asap.
Thanks again!
https://www.sau.com.au/forums/topic/234713-paint-correction-on-r34-gtt/
Mate It depends on the damage done to the car, In my eyes my car looked ok.. Soon found out it was pretty crap, All the water etching etc ruined the paint.
Mario managed to put in 12 hours of solid work, Its well worth it.
Contact PolishDoc via PM on here thats Mario - You can also see his other work Search for " Paint Correction"
Edited by DECIM8
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
