Modifications
Interior
Velo Bucket Racing Seats
Blue RPM 4-Point Harness
Autotechnica Steering Wheel with Boss Kit
Autoguage 5" Tacho and Shift Light
Trust Twin Pillar Mount Holder
Greddy Mechanical Boost Guage
Pivot 3in1 Speed Meter
G-Zone ECU Racing Chip
Aluiminium Pedal Extensions
Neons Behind Dash
Pioneer MP3 Head Unit
V-Net 4100 Amplifier
Kicker KX200 Amplifier
Pioneer Compression Horns
Clarion 15" Subwoofer
Uniden Scanner
1kg Fire Extinguisher
Exterior
R33 GTR Fibreglass Rear Wing
GTR Front Grille
GTR Bonnet
Custom Cut Stock Front Spoiler
Apexi 3" Muffer
3" Front Pipe
Custom 3" Exhaust
3" Cat Pipe
5 Puk Heavy Duty Clutch
Apexi Lowered Springs
Underbody Neon Car Kit
Grade 15 Window Tint
Short Shifter Kit
Under the Hood
Blitz Metal High Flow Air Filter
Custom Exhaust Manifold
Custom Intake Piping
Twin RB20 Turbos
NKG Iridium Spark Plugs
UAS 600x300x75 Front Mount Intercooler
Aluminium Mandrel Intercooler Piping
TurboSmart Dual Stage Boost Controller
GFB Mach 1 BOV
Cyclops Paralyser P350 Alarm System
Performance to date
13.7 @ 104mph 60' 2.28
~200bhp @ 13psi (1 Turbo)
https://www.sau.com.au/forums/topic/23475-all-my-mods-i-think/
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
