I was told by the guy who built my engine that the area that the oil pump attaches to the crank is superior......It was only last Friday I was told by someone else I trust a little less, that there is no difference, and that a 33 crank would need a collar to ensure the oil pump had a good grip on the crank.
I too would like to hear the answer to this one.
Whoever you trust - dont trust them cause they are horridly wrong.
R33 does NOT need a collar.
As for pics/difference... plenty of threads. Its just the oil pump drive. Thats it.
http://www.skylinesaustralia.com/forums/Cr...l&hl=collar
http://www.skylinesaustralia.com/forums/Pu...l&hl=collar
http://www.skylinesaustralia.com/forums/Rb...l&hl=collar
Hey guys like the title says im trying to find out the differnce between the 32 and 33 gtr crank any help will be appreciated.
Ive got pics here somewhere.
Notice the larger surface area of the flattened oil pump drive on the snout of the crank on the R33 item. The R32 is significantly smaller. You can see why they crack oil pump gears.
so this crank look to be either a late modle r32 crank or r33 crank?
That third pic sucks, but it appears to be an R33 crank.
You just saved a grand on a new crank! Now you can go spend it on a million other things needed for what you are doing. Ive been there!
Shaun.
hey shaun thanks for the info. I actually bought the engine as a running standard r32 engine got it home and the insides were stuffed but thankfully it had those magic numbers on the side 24U :) and now it has a 33 crank thank you god!!!
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
