hey all
got an R32 GTR
it has an Apparent OS Giken Triple plate clutch in it, this thing has f all friction point and just grabs so i assume its some sort of aftermarket thing
now the problem is
its perfect when driving no problems shifting at high revs or anything like that just a few noted below
sometimes i start the car up after driving for a bit and push the clutch pedal down to engage gear it will not let me select a gear have to switch the car off then select gear then hold the pedal down but even then it will lurch forward and start to move, sometimes i will rev it to like 5k try and select and it will just grind a bit and still will not select the gear..
and sometimes coming up my driveway i select first and disengage the clutch but then when i put my foot down to deselct first it will still say in gear and stall?
anyone know what will cause these problems?
should i adjust the master cyl pushrod? bleed the system, change the fluid?
Thanks for your help
Edited by urbanoperations
https://www.sau.com.au/forums/topic/235225-r32-gtr-clutch-problem/
sadly, if it happens intermittently it's most likely, a damaged/bent clutch fork, or damaged bearing carrier, or worse damaged pressure plate. that is why sometimes it's fine, and sometimes the clutch wont disengage.
  • 3 weeks later...
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
