Make: Nissan
Model: 1989 R32 GTR
Milage: 113XXX
Transmission: Manual
Colour: White
Complied? Yes
RWC supplied? Upon Deposit
Currently registered? Yes
Price: $27,500
Contact: Chris 0404 495 420 or [email protected]
Comments / Modifications:
Engine:
CP Forged Pistons 86.5mm and rings
HKS 264' in\ex cams
Adjustable cam gears
High flowed ported and polished head
Stainless steel multilayered head gasket
R33 reman crank (larger oil galleries)
Eagle Rods
ARP main studs
ARP enlarged head studs
N1 oil pump
N1 water pump
Tomei oil restrictor
Block crack tested, honed and decked
ACL race bearings
New Gates Timing belt and genuine idler and tensioner
APEXI Power FC w/ hand controller
HKS 550 injectors
Super Direct ignition coils(red)
Braided enlarged fuel lines
NISMO Fuel pump
NISMO fuel reg
Turbo and pipes-
HKS T45s turbo Rebuit
HKS 55mm Wastegate
HKS power intake pipe
HKS low rise manifold
HKS pipework and intercooler
3 inch fujitsubo exhaust system
OS Giken Triple plate clutch
Brakes and Suspension-
HKS Hypermax 2 coilovers and springs(excel condition)
CUSCO rear stabiliser
CUSCO upper arms 10mm shorter
Aluminium spaces and new bushes
R34 Brembo Callipers with recent overhaul
New 330mm Rotors and pads front
R34 master cyl with CUSCO brake stopper
Rear brakes standard but slotted
Saftey 21 5pt Roll cage(complied)
Recaro Drivers Seat w/ bride rail
Mines 320km speedo
D Speed Dry Carbon bonnet
Ganador mirrors (electric)
N1 headlights
Jap Spec clear indicators
oil temp, water temp, oil pressure, air/fuel ratio, boost gauges
Wheels:
275/30/R19 MAAS MKX Machine Faced Black w/ Kuhmo tyres (good tread)
Images: Sorry about the size, but I hate it when people post up for sale threads with tiny or no pictures. I have plenty more so if they shall not suffice, just send me an email and ill send you more.
https://www.sau.com.au/forums/topic/235346-1989-r32-gtr/
Do you have pics of the engine bay, interior, dyno sheet. Would you sell without the rims. I'm a genuine buyer, not a tyre kicker. I've had a look at a few 32's now and am disapointed at the overall condition.
https://www.sau.com.au/forums/topic/235346-1989-r32-gtr/#findComment-4160909
    • Hi GTSBoy, Excuse my ignorance but what does a "Bad" Knee point mean ?
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
