yeah sounds a bit too high, my 34 with exhuast, fmic, ~9psi, pod makes 185rwkw, so id guess on 11psi ish youd be at 185rwkw-190rwkw. how have you achieved that boost increase?
Jeff at turbo tune said something on the lines of the stock solenoid has a high and low setting. Mine started at 6 psi and then made its way up to around 11.5. When I get the dyno sheet scanned you'll see where the boost increase will be.
  • Replies 54
auto salon was dead on actually. i had just got my car dyno tuned at boost worx a week prior and it made 2kws more than it had been tuned for.
anywho.. i dont find it hard to believe 200. i mean 11.5 is lot of boost for a rb25.
The Autosalon dyno was the Graham West dyno, yeah?
correct cronic.
Zak, yeah you've got a real gem of a 33 there, seems your fmic and exhuast is working very nicely with your engine.
And Steve, i was just asking how he achieved the boost increase, a jump to 11.5psi from just minor mods isn't seen too often.
Edited by Damo_R34
yeah i edited that, it came out completely wrong lol. 6psi sounds like a fair gain in boost, i wouldn't mind having mine looked at. Guess i'd start with hi flow/no cat and removing the restrictor.
201 is a too me sounds about right.
i made 205 with the same sorta mods when i had me ebc fitted and set at 11 psi...
got alot more now though :P :P
Edited by craig R33
he wont be able to add it now Dale, you have 10 mins to edit your post unfortunately. Has a nice increase at 150kw's, Jumps to 170!
I think you'll find that that is AFR related. the factory maps are a bit all over the place as they are only tested at certain points in the rev range not over the whole range. So at the points were they are tested they have good emission's and every where else it's tuned for safe power.
Zac has an SAFC II in the car but it hasn't been played with at this stage and has 0 correction factor at every point so when he takes it to Jeff next the AFR's will be more constant and there will be a bit more power (~10kw).
P.S. thanks for letting me know about the editing time, I never could figure out why you could edit your post some time but not others. On NS where I do most of my posting you can edit it any time. I guess it pays to be a post whore on more than one forum.
Edited by D_Stirls
wheres the Dyno settings at the bottom Dale
i thought it was more like 30mins editing either way we need editing rights
I'm not sure where the info is, I just checked the printout and it's not on there.
But I also looked at the printouts for my car that were done on the same dyno and there aren't on there so it might be the way TT have there printouts setup. I would say the the temp are correct because every time I have seen Jeff drive a car on the dyno the first thing he does is enter the humidity and temp from the weather station they have setup next to the dyno.
Ive been in and driven IZZMO 33's car and it feels very much like 200+rwkw with minimal mods aswell..very impressive.
to me that dyno is reading a wee bit too high
i had my car dynoed at Willall Racing and they use a mainline dyno
with a front mount, boost increase to 9psi, full zorst, splitfire coilpacks, pod....my car made 188.7 rwkw on a reasonably warm day
so from the mods that you are saying you have i would expect the same sort of power that my car has pulled out
plus no boost controller and ur hitting 11.5psi....umm have you had that reading out off a boost gague or from the stock gauge.
My R31 with series 1 rb25det and my r33 with series 2 rb25det both made 203rwkw and 205rwkw with 10psi, cooler and exhaust on a few different dyno's give or take 3-5kw
You WOULD have about 200rwkw if there was an aftermarket computer or your ecu has been remapped........
not necessary mate. Every car is different.
over 30 posts and no one has mentioned ramp rates.
how much brake against the rollers.........you need to compare apples for apples
God dam it pete, you beat me to it! hehehe
People dont realise that its up to the dyno operator to choose the specific ramp rate that the dyno produces...this alters your power output...usually a standard ramp rate for these things is around 150.
So many people are quick to assume every car is the same and will make simular power with simular mods. Every car is different. So many variables come into play when it comes to output on a dyno...remember people its just a number.
Edited by Ryanrb25
oh and i forgot to mention we've had plenty of 33's on the dyno at Aussies and alot of them make good power (190-200rwkw) with basic mods yet others make average power (160-180rwkw) with simular mods...SO many variables. Believe it or not other cars have had a much harsher life than others.
Edited by Ryanrb25
and some over 300rwkw Ryan...lol
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
