Hi guys, I need some help, I picked up a used Greddy exhaust gas temperature gauge yesterday. It's the current style with the separate controller and gauge with max reading recall and adjustable preset warning.
As usual, no instructions, so I need help with the wiring. It has 3 wires going to the control box;
1. black (I assume earth)
2. red (I assume switched active)
3. white (I assume switched light for the gauge)
But I am too chicken to connect it up in case I am wrong, too expensive to blow up by getting the polarity around the wrong way.
So does anyone have a manual, wiring diagram or remember when they wired their's up?
https://www.sau.com.au/forums/topic/23551-greddy-egt-gauge/
Thanks guys, I won't have time to fit it until the weekend after this, too much important racing on this weekend. So I figured I'd just ask around, there must be someone who has fitted one that knows for sure.
https://www.sau.com.au/forums/topic/23551-greddy-egt-gauge/#findComment-505969
Hi 2rismo, excessive exhaust gas temperature is a good warning of too lean mixtures. I can tune the car on the dyno with the fast and wide lambda sensor plugged in and know the A/F ratios are OK and what the max exhaust gas temperature it is runing at (say 700 degrees C). I then set the alarm on the EGT for slightly higher than that (say 720 degrees C). If for some reason the car leans out (stuf like fuel pump failure, dicky injector, blocked filter or bad batch of fuel) then the alarm goes off and I save an engine.
There are other uses, but that's my main one.
So anyone got a wiring diagram or personal experience?
https://www.sau.com.au/forums/topic/23551-greddy-egt-gauge/#findComment-510879
Hi 2rismo, you asked "better indicator than knock sensor in car/pfc?"
Not really better, but definitely a good support, you can get knock without too much excessive EGT and vice versa. Plus the EGT is a good indicator of exhaust valve condition. A "burnt exhaust valve" is really a "burnt" exhaust valve, if you get my meaning. The temperature to "burn" it ended up in the exhaust and the EGT sees that, but there may be no knock.
Hope that makes sense
https://www.sau.com.au/forums/topic/23551-greddy-egt-gauge/#findComment-514136
Hi Guys, I picked up the Greddy for $195, I missed one a couple of weeks ago so they do come up from time to time. Juts have the cash available, be ready and move swiftly, they sell quickly.
As for temperature in your car 2 rismo, you have standard turbo is that right? Then I would recon on not much over 600 degrees C for too long, maybe 700 max.
https://www.sau.com.au/forums/topic/23551-greddy-egt-gauge/#findComment-515237
I love my Greddy EGT on my turbo integra. I know it's off usually by a hundred or so degrees but it's better than nothing. The reason for this is because the indicator can not take readings as fast as the gases are coming out so you sometimes get a delayed response. I'm not sure which runner in skylines run the hottest but hondas tap into the 3rd runner usually. By the way, a friend had pretty much the same set up as me with an Autometer EGT and it took longer to read. I hooked it up to my car and the same thing happened. Good choice on the Greddy EGT. Good luck hooking it up.
My EGT:
Black = ground
Red = constant
White = light
I think my EGT is about 2 years old though.
Good luck.
https://www.sau.com.au/forums/topic/23551-greddy-egt-gauge/#findComment-515420
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
