Item: Set 1 - ROH Drift R, 17x8 +35 & Falken FK452 tyres
Age: unknown
Condition: Excellent - 0 gutter rash.
Price: Asking $700 with the tyres, or $550 without tyres
To Fit: Skyline (32,33,34), Stage, Legnum - 5x114.3
Contact: Post here or PM me
Comments:
Perfect offset for Legnum/Skyline/Stagea with 0 gutter rash! Tyres are 245/45/17 Falken FK452 (awesome tyres) with ~80% tread at the front, and ~10% at the rear.
As seen here on my legnum (for trial fit)
Item: Set 2 - BIM Zeit alloys (made by bridgeston Japan) 17x7.5 +47 & Yokohama S Drive Tyres
Age: unknown
Condition: There is gutter rash
Price: Asking $650 with the tyres, or $450 without tyres
Comments:
As came from Japan with my Legnum. They do have gutter rash on each wheel, however I can sand them back and can have sprayed in whatever colour you wish. Tyres are 215/45/17 Yokohama S Drives with approx 70% tread left. Tyres are absolutely fantastic, very grippy, and with the wheels cleaned up will be excellent package
https://www.sau.com.au/forums/topic/235645-fs-2-sets-17-wheels/
gonna need a pretty large spacer to clear skyline brakes mate. prob at least a 10 - 15mm bolt on just to clear brakes.
Edited by jeffers1987
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
