  • Replies 47
Posted Images
As I said on previous page mine has made a safe 326.8kw at southern Hi-tech dyno using N1s.... so, YEP!! :D
Having said that.... if I did have to change turbos I would definitely go the 2860s.
Edited by HOSTILE
AHH oh cheers!
ill have to keep an eye out for people selling a set
I reckon Ryan (ISC performance) was saying he would go to the 2860 - 10s if he was gonna do it again.... any comment ryan??
But yeah, seat of the pants test in shanes (puresx) GTR, those 2860s (-5s) hit pretty hard! :D
I've experienced a ride in an R32 with 2530s(=2860-5) which are quite nice, but that car was running R-Compound and already felt damn scary. Sorry, I don't think I have the balls to have something with that type of power delivery in a daily driver :D
Maybe with some more confidence and experience with a higher power level may change my mind...but I'll wait and upgrade instead of jumping in too deep
I'm currently running the 2860 -5's which are a smidge bigger than the N1's and still relatively responsive with good power.
Is anyone running a pair of 2860 -10's or HKS GT-RS (virtually the same I think) on their GTR that can comment on response sacrifice vs power gain?
The - 10's are laggy, so cams are a good idea to combat the lag but you will still get it :)
I love the -5 there very responsive and looking to get them on my car soon, Basically same as R34 N1's
There is also the HKS 2530's
that group buy is a couple of months on since he was able to get those prices still......would be worth shooting him a PM to see if he can still do that.
There is a price for -10's in that thread as N1GTR was asking about them, read through the pages :)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
