  • Replies 47
Posted Images
As I said on previous page mine has made a safe 326.8kw at southern Hi-tech dyno using N1s.... so, YEP!! :D
Having said that.... if I did have to change turbos I would definitely go the 2860s.
Edited by HOSTILE
AHH oh cheers!
ill have to keep an eye out for people selling a set
I reckon Ryan (ISC performance) was saying he would go to the 2860 - 10s if he was gonna do it again.... any comment ryan??
But yeah, seat of the pants test in shanes (puresx) GTR, those 2860s (-5s) hit pretty hard! :D
I've experienced a ride in an R32 with 2530s(=2860-5) which are quite nice, but that car was running R-Compound and already felt damn scary. Sorry, I don't think I have the balls to have something with that type of power delivery in a daily driver :D
Maybe with some more confidence and experience with a higher power level may change my mind...but I'll wait and upgrade instead of jumping in too deep
I'm currently running the 2860 -5's which are a smidge bigger than the N1's and still relatively responsive with good power.
Is anyone running a pair of 2860 -10's or HKS GT-RS (virtually the same I think) on their GTR that can comment on response sacrifice vs power gain?
The - 10's are laggy, so cams are a good idea to combat the lag but you will still get it :)
I love the -5 there very responsive and looking to get them on my car soon, Basically same as R34 N1's
There is also the HKS 2530's
that group buy is a couple of months on since he was able to get those prices still......would be worth shooting him a PM to see if he can still do that.
There is a price for -10's in that thread as N1GTR was asking about them, read through the pages :)
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
