Ok guys and gals.
This is manly for the old crew, but more the merry!!! Time for a catch up and a few drinks like old times!!!!
Ok the Choir boys are playing at Olims $20 plus 10 free beers cant beat that value!!! The date is next weekend.
Please post whos coming.
The kick off is early 10am but none of us will get there till about 12ish (a normal drinking time) So in so far is
(post user name)
See you old timers there (and always the newbies are welcome too)
Race_snooze
Sinister
https://www.sau.com.au/forums/topic/235822-for-the-old-crew-and-the-new/
hahaha 10 free beers, are you serious?? :)
I'll come... dont think I'll manage 10 beers though, can you pass them on to someone else? Oh hang on, I've got an idea, someone give me a lift from the southside and I'll give you FREE BEER!!! hahahahaa
Race_snooze
Sinister
Shell
If we get there earlyish there will be tickets at the door. But dont leave it to late, not sure what will happen then. I have Hockey grand finale day afterwards too so I might not drink to much while I am there
Edited by race_snooze
Feline.....Yeah thats right p_u_ s_s_why? (jokes)
We all know hockey playa's are a bunch of coke suckers :thanks:
Edited by Sinista32
bugger, I'm at the Bulahdelah Speed Weekend this weekend.
Richard will have to be mum for this one :( but knowing Richard, he'll be the one leading you all astray.
Michelle, Shell, Kat ~ get your cute ones down to Olims. Yep will lead the Stray cats aStray.
Im happy to take you Shell in my sh!tter if your down south or on the way. ;)
Mayhaps be booking a room for the night so you may need to get a lift home tho.
WTF why you going interstae Michelle. You racing in F1 or doing the QTR ? You see the Silver GTR 4Sale at DAFF ($20k) looks straight and has less than 70,000 klms genuwine!
pfft Michele I'm perfectly capable of leading myself astray... dont need no one else to do it! haha
ps where the hell is Bulahdelah ;)
Richard, I'm in Kambah, if thats on the way let me know :( ... a lift would be tops
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
