Ok guys i got heaps of parts for sale, open to offers. Ill update info as i get it. Parts are in west side of melbourne, will post at buyers expense. More parts are available, engines have been sold however and most front ends parts are gone already (including front lights, bars, fenders). Other parts are still on car post for price and availability
Front Brakes $200 set
Rear Brakes $200 set
x2 Starter Motor $130 each
x2 Air conditioner Pump $70 each
Power Steering Pump $70 each
x2 Intake Pipe $50 each
R33 Turbo (Good Condition, was working fine before taken off engine) $400 each
x3 Engine Mount $40 each
x2 Cross Over pipe and BOV $100 each
R33 Left Lower Control Arm $100
R33 GTST Front Sway Bar $70
R33 Front Lower Supports $70 each
R33 Front Castor Rods $90 each
Auto Transmission Cooler $80
Front Left & Right Axels $150 each
R33 GTST Engine Loom $60
R33 Carpet $90
R33 Seats $150 set
Assorted Plastics 1 $30
Assorted Plastics 2 $80
Assorted Plastics 3 $80
Assorted Plastics 4 $40
Edited by Osman R32
https://www.sau.com.au/forums/topic/236078-heaps-of-r33-parts-forsale/
hey osman
im after the heater hose that goes from the block to inside the firewall
please tell me you still have it
thanks
emre
should have one but i am unsure which pipe it is. do you have a picture, as those lines are still on the car, and the car has no engine so i cant confirm which one is which.
-osman
how much would u think for the front and back brakes to get posted form mel to nsw central coast? as i want bigger brakes on my 180sx and i heard that the r33 brakes go straight on and r much better than the stock 180 brakes.
if you buy both ill only charge you $10 and ill cover the rest
pm me for account details if you want them
need parts for stolen and recovered r33 gts-t
full ignition barrell, turbo timer, gear knob, ecu all the intake from pod filter to turbo including intercooler, b.o.v, coin tray, battery, rear boot flip lock thing, centre bit for between box and gear shifter, series 2 passenger door trim, 2x front quarters, series 2 grill could you help me, how much thanks 0404099310 live in melb west can come and look.
will call you to organise a time and you can pick what ever you want or need off the cars
  • 1 month later...
Hey mate, interested in the dash surround(assorted plastics 2) and the interior carpet, how much for both and postage to Burnie Tasmaina 7320, thanks, please pm me with a response
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
