?? i paid under $1500 for mine, i have nfi where ur getting ur figures from.
once again, we are talking about an R32 GTS-t. not 100% how u talking about ur R34 GTR is relevant here.
no arguement there pal, but you asked a question (see above).............and now you have an answer, lol :)
  • Replies 124
Posted Images
btw i run the bilstein/eibach combo with the "coilover conversion kit", 6/4kg, that ended up costing around $2200ish. i bought these to suit the track, i wouldnt have bothered with them if my car didnt see a lot of track work.
huh...... :)
so i guess a 6/5kg would be ideal with stiffer sway bars and if i went on track with the 12/10kg then soften up the sway bar a little ?
for drift u could get away with the high spring rates, will make the car easy to snap around the place and very responsive/controllable, but u will sacrafice grip and speed. the high spring rates the japs often run is more to do with their style and the trend over there, their style is more about quick responsive moves, tight transitions, high angle etc. and there is less emphasis on grip and speed.
but for grip u really want a much more balanced setup.
huh...... :)
i started off with the street setup with bilstein dampers and soft street springs which cost $1500ish, now im running a track setup with eibach springs/adjustable seats with the bilstein dampers which cost $2200ish, 2 different setups which both share bilstein dampers.
wasnt a question exactly (yes i know there were question marks :) ), but remember u were the one that posted up $2500 figures first in a thread about R32 GTS-t's. i was just trying to defend the idea that bilsteins are very expensive and u can only afford them if ur rich, which just isnt true.
Bilstein if you're rich
ok, well that makes more sense then.......so in actual fact you answered your own original question about my price of $2200.........my springs are stamped "Bilstein" but probably came out of the Eibach factory in Europe as well.
So I'm assuming your first springs were Whiteline or similar?
EDIT: Bilsteins are twice the price of the Jap stuff.........and twice the shock, lol
may have to let you have a look and a drive of it stewy
haha nah just get the thing out there and get a feel for it and go from there, see u at october prac day? :)
but yeh, if u want ur grip u really need to drop the spring rates a bit and chuck some nice adjustable sway bars on there, then at least not only will u gain some grip, ull be able to balance ur car out much better with the adjustability in the sway bars.
i didn't mean a drive on track just on the roads get my damper and stuff sorted suspension is a fine art and if you know nothing about it like myself you set it up wrong and just blame the roads for bad handling
my first spring were king springs but i didnt want to confuse the situation haha, the kingies were basically identical to the whitelines in the group buy, i already had them in so didnt see the point in buying the whitelines when i had the kingies.
as i said, u dont need to be rich to own bilsteins, the basic street package is more than enough for most people that drive their cars on the street and a bit of track work, and that only costs $1500 for the damper/coils.
haha yeh and thats the thing, too many variables on the street, setting up suspension would be hard enough on the track let a lone on the street.
I think Fabs32 has pretty much got the message now about the best way to go in relation to his original question, so back to my problem ;)
Having a true PSS9 kit with 400lbs (7kg) Fronts & 455lbs (8kg) Rears........I'm thinking of changing the rears to approx 5 or 6 kgs.....any ideas?
SK wants $225 pair springs with a very long wait..........I'm sure I could get something quicker and maybe cheaper from somwhere to suit the Bilstein setup.
Springs are springs...there's some difference between cold wound and hot wound ones but most manufacturers now do cold wound springs. So long as the spring profile matches, find them somewhere else.
Do you have adjustable swaybars in the rear Sled?
yeah bud I do. Can you recommend anyone that does a decent pair of springs for what I'm after?
    • I sense an out of control build thread coming up lololol. That 450kW goal will end up being 600 to 700kW LOL.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
