hey guys im pretty intent on buying a car from brisbane, has roadworthy and rego. but i need to get it to alice springs in the nt, was wondering if anyone could point me in the right direction of a good transport company, ^move my car^ or such? and about how much it would cost?
also how would i transfer the rego over? cause both parties have to sign the rego papers in order to transfer the rego? how do you normally go about transfering rego from interstate?
any help would be great,
thanks in advance :down:
https://www.sau.com.au/forums/topic/236316-transporting-cars/
theres a few getin around now days. there is tnt, ceva transport that carry the autosalon drift car www.cevacarcarrying.com.au and gibson freight www.gibsonfreight.com give them a try. As for the rego not 2 sure best to ring ur local trafic authority and ask them bout it.
hey guys thanks for the help, i looked up those two sights you recommended but they wanted to charge me an arm and a leg, i found move my car to be the cheapest so far, thanks
if anyone thinks of anymore could they please post them for me :P
cheers
Ryan
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
